Is there a relief valve in or after the VP44 injection pump that might stick open? At startup I have good pressure 16 psi. But, it take very little pedal to really pull it down, and at 1/4 throttle it would run down below 5psi. I thought maybe my pickup was bad of restrictive in the tank so I replaced the stock plastic with a 1/2 steel pipe for a pickup. This helped a bit but still not the answer. So is there a valve the could be open causing the pressure to dramatically fall off. FWIW, relief valve in airdog seems to be working properly.
