2nd Gen Non-Engine/Transmission fuel pressure
Engine/Transmission (1994 - 1998) ATF III or +IV ???
Engine/Transmission (1994 - 1998) Which weight Amsoil should I use?
ok i got a 2001 speed with edge drag,fass 150,draw strawII,hrvp... my fuel pressure at idle is 19 i can get it down to 8 is this ok or is it to low?? what can i do to get more pressure??
i got the FASS 150 GPH Pump Kit 98. 5-04 Dodge Cummins and the draw straw 2 because i had the intake pump... so u think it is my guage??? is so what cani do to find out... it is an electrical guage. so right now my truck dosent have a lift pump right?? just the fass pump can i put a stock lift pump back on it to make it better or do you think its the guage?? thanks 4 all the input!!!
ok so changed my regular fuel filter then hooked a mechiancal guage up on it at idle its has 19 1/2 psi and i can get it down to 10 psi is this ok or not??i am thinking about getting a mechaincal gauge will it be ok to mount in the cab or should i mount it on the hood???thanks
Diesel-Dan said:
With all our wnty issue, we hold our dealers accountable for their customers and run all our wnty through our dealer network. I ask that you contact your dealer because i feel we might need to send a pump out to you because i don't like the pressures you are seeing at WOT. This all pending on the wnty status of your unit. I will be back in on Thurs. since we have the 4th off. Call your dealer with your SN and we will go from there. Thanks!
Dan
ok i sent him an email to call you my dealer is vulcan performance the serail number is 7043 if you need to know and i hear this all the time what does wot stand for?... thanks for all the help Seth
ok dan got my new pump put it on changed both filters and this pump is just like my old 1 this 1 idles at 18ish and drops to 9 easy hooked up 2 diffrent guages same readings... what do i need to do?? thanks
seth did you ever have rock solid pressure with your draw straw? just wondering if it is plugging itself on the bottom of the tank.
do you mean just like at idle? or do you mean its dosent drop at take off?? but its is cut at the angle and i took it out yesterday and put it in again. .
i checked it with a banjo fitting with a mechanical guage and my my electrical guage ... so does that Mr. Gasket ''Barb'' Fuel Pressure Gauge Fittings - JEGS just cut your fuel line and tap that in to it with a mechanical guage? i dont know i am just frustraded ... like i said i had the whole fuel tank out again saturday removed the draw straw cleaned out the tank and checked 4 pinches and put new filter and the new pump on still nothing??? i just dont know... also where do i send my old fass pump back 2 i got a rma number just didnt know the address??thanks let me know
ok sounds like a plan i will ship the pump out this afternoon or 1st thing in the a. m i will just wait for you to inspect the pump see if there is anything wrong with it if not them we will go from there... with the jegs fitting will my fuel pressure sensor work or will i need to get a mechinal guage??thanks
ok thanks i ordered a new fuel pressure guage from vulcan and the has been shiped sorry for the delay hope you didnt mind let me know what u find out about the pump thanks
