The lack of LP on the Duramx's causes issues, they just won't admit it. As a geenral rule on a stock Duramax, an LP adds 40 hp to available power. They don't make full power without an LP, they just run decent with what they can draw. Was chatting with a friend last night and he just had a DMax in his shop with a complaint of low power and low mpg. All he did was add an LP and the customer was ecstatic. Power came back and mileage was up.
The CP-3 is not exactly the same. The Gear rotor pump is a different design that is aimed more towards pulling fuel, the lines are larger from the tank to the CP-3, and the tank location is higher in relationship to the CP-3 than in the Dodge application. It all makes a difference.
The Dodge trucks will run home if you are careful as long as the pump doesn't seize and block the fuel inlet, kinda depends on what exactly fails. If the LP ever dies and you have to break the system, they will likely never prime again. The CP-3 simply cannot pull fuel that far.
