Fuel pressure
Update On After Market Lift Pump
5 Speed Or 6 Speed?
What pressure is considered good at idle
what pressure is good at wot.
what fuel pressure guage is good?
Thanks for any and all replies
Jim:confused:
carhauler- my truck has 12. 5 psi at idle,5 psi at wot (in a extended run not momentarily) and all the guages I have are Auto Meter ultralites
mine did--you'll need a adapter line to come off the schrader valve on the fuel filter to go to the pressure sensor that comes with the guage--the adapter line I used was a old end/section from a junk set of freon guages I had laying around,it works for me
