Low1lbs fuel pressure
I just sent to Jannetty Racing for a Fuel up grade. A set of 100GPH (15lbs just running) Fuel Pumps, new lines and fittings to the injector pump. My present problem is at full throtle I get 1 pound of fuel pressure and the truck engineh bucks like someone shut the fuel off and on 3 times fast between the rpm range of 2600 - 2800 after that things are fine but I still get a low fuel pressure warning on my FMS from Blue Chip. I have an 01 with HX35,14cfm turbo, DDII, A Blue Chip FMS, Puck Timing Box, Trans shift Kit
After 3 Months and three new fuel lift pumps, no one knows what to do. The latest "fix" was a new ECM from dodge all this did was put the truck in "limp mode" I went back to the old one. And back to the same problem. The next trick is a new converter, the thought is that the tuck is spooling up to fast and sending a code to the ecm to shut down the fuel down until aftere the curve is over Will see.
Steven TDR Member
