We've had a couple customers who have had seal failure while running 28+ PSI fuel pressure.
I'm not sure why you'd ever want your pressure that high in the first place. A properly designed fuel system should deliver stock pressure, or at least near stock pressure at idle, and should not lose much more than a couple PSI at WOT. That way you KNOW that you are not having a fuel starvation problem. Remember, Bosch has a 19 PSI cutoff built into the pump, and there is obviously a reason they decided to do this. Open up the lines to a good size, toss the pusher pump in the trash, and run with a good single pump that has a max pressure of around 19 PSI.
Rod
