My truck died yesterday but not all at once. I stopped for fuel,having felt the truck sputtering a little. Filled up,turned the key,good crank but no start. Tried several min. before using starting fluid. It started and would run ok but no idle. Also had 1/2 power loss. Every time it died it wouldn't start w/o start fluid.
I tried to limp it home. Got 5 miles from home and it died worse. It will start/fire w/ start f. but will not stay running at all. I cracked open #s 1 and 3 injectors and fuel did come out when I cycled the key. Also,when it died my fuel pressure gauge tapped to my FASS pump was reading 9 lbs.
The VP 44 has been remanud. already. I changed the fuel filter the night before. How do I check for injector or injection pump failure?
I shudder to even think about a new pump. Can someone give me some help?
Thanks.
Thanks.
