I have been having problems with fuel! I had the C3P replaced and thought that was the problem! It wasn't. Basically it's like the truck is de-fueling especially in 5 and 6th gear. The truck is also makes more noise in the cab when it runs rough. I talked to Larry at Ekstam, he feels it's not the air dog. I know the injectors are ok. The truck runs good for about a mile then it start to run smooth again. When the truck runs good I can see 43lbs and 1600 egt no problem, when the truck runs rough 30lbs and 1200 egt's. The pedal feels weird from 1/2 to full when the truck is running rough. Any ideas????
