My truck died Sunday. After priming the filter I was able to get it started again. I was able to pull the following codes P0088 fuel rail pressure signal above maximum limit, P0148 high-pressure common rail (HPCR) check sum and P0483 fan speed. This is the second time in 2 weeks this has occurred. The first time i changed the filter (400 miles ago). Only had the fan speed trouble code the first time. Is this the lift pump? The truck only has 44K on it, 04 3500 5. 9 4x4 with automatic.
