Just purchased a basket case, 95 2500 Regular Cab truck with a fuel problem. Found bad lift pump, replaced, now have fuel to injection pump. I don’t hear the overflow valve popping off like the last three Cummins I’ve owed but I know fuel is getting there because the return fuel line is leaking (repaired), so I pulled the valve and stretched the spring, still don’t hear it pop. Tried starting with two injector lines cracked but no fuel is getting to the injectors. Found the shutoff solenoid not engaging , if I push the solenoid up it will hold so I checked for fuel at the injectors again, still none. :{
This is where I’m at until Monday when an overflow valve I ordered should show up (I have one can’t find it). I believe this will be the last thing to get fuel to the injectors but I’m open to any info you may have.
Thanks
Thanks
