Gauge is an Isspro 30 psi mechanical, hooked up post filter and ran straight into the cab. The lift pump from Hoesli diesel is 4 months old with ~10K miles on it. I just noticed 2 weeks ago that the pressure would drop every now and then down to 5 psi while cruising, then go back to 13-14 psi. I've really been watching it the last few days, and this morning it stayed a little below 5 psi my entire 50 mile commute. When I pulled into the parking lot, sure enough I notice that it was reading back normal again. I shut the truck off, then turned it on and bumped the starter... the gauge bounced a couple of times before climbing to 15 psi. Started the truck, and it's reading 14-15 psi at idle, but it's climbing and falling 1-2 psi. It's always been pretty steady in the past. I've changed the fuel filter. Do these mechanical gauges have problems like this? I haven't experienced watching a lift pump going out... when I installed the gauges mine was reading a solid 8 psi at idle and would drop to 1 psi @ WOT, so I replaced the lift pump. Do the pumps act intermittent like this? I don't suspect air in the gauge line since it's always read rock solid since the install. Experiences??
