Do not add any motor oil to the fuel! It won't burn well, will varnish up the injector parts and can gum up the piston rings. Check the fuel pressure going to the high pressure (CP3) pump; it is likely that the stock lift pump has failed (Geno's carries replacement pumps, an adapter to check pressure, and has a discussion of lift pump options in their catalog).
