fuel pump ??? 04.5
Advisement on Turbo(s)
Help, I need 2 of these Exhaust hangers.
Which banjo fitting on the fuel pump is the output from the clean side of the filter? I'm installing a fuel pressure gauge and the people at Geno's were not sure. Is it the one closest to the cab or closest to the radiator.
actually there are 4 banjo washers I just replaced my stock fuel lift pump with airdog and removed the stock filter and pump G D removal kit but still needed to replace banjo washer (gaskets)I figure if you replace 1 replace them all at the same time cheep and only do it once.
