Archived Fuel Pump Blues!!!
Archived Wont Crank after injector install
Archived Head bolt streach spec
NEED HELP AGAIN GUYS!!! I recently installed a fuel pressure gauge on my 98. 5 5 speed, and then posted that I had NO fuel pressure. I just replaced the LIFT PUMP and this solved my problem, now I have around 15psi. . But NOW the engine seems to stumble a bit while idling. I have consulted my mechanic and he seems to think bad FUEL PUMP!! I DID NOT WANT TO HEAR THIS. . I plan on taking the DODGE down to the Cummins shop in a couple of days to have them run some tests.
Anyone else had this problem?? Any help appreciated, the TDR RULES!!!!!
1998. 5 SLT, EDGE CHIP, 4" EXHAUST, AUTO-METER GAUGES, WESTACH FUEL PRESSURE GAUGE, UPGRADED STANDARD TRANS, STAGE 2 CLUTCH, FIRESTONE AIRBAGS---RUNNING OUT OF MONEY 121,000 MILES
2001 ALFA GOLD 5TH WHEEL 35' Oo.
Check for fuel leaks - make sure all your fittings are on tight. Also, make sure you get all the air out of the system, you might still have some in there...
