I'm replacing my mech LP with the FASS setup. I'll be removing the lift pump and placing a blockoff plate with the fuel heater back in its place on the blockoff plate. Any one know the size of the fitting coming out of the heater to the short curved rubberhose? I want to use AN fittings. Need the diameter and NPT size. Then I need the same help with the bolt size going into the P-pump. There's a banjo bolt to hard line there now. I'm eliminating the factory filter head mount on the engine and going straight from fuel heater to P-pump. I'm leaving the fuel return alone at this time. Any help would be greatly appreciated.
