I have an 03 with the original pump on the filter housing:
Questions:
1. Is the "original" pump a "flow through" type? In other words when or if the original pump fails and is replaced with an in tank is the failed pump retained in the stock position and simply pumped through?
2. After the intank pump is installed if it fails can fuel be pulled through it by an original style pump in case it fails while on the road?
I have reviewed the "replacement" proceedure on the original pump at the fuel filter housing and have considered having a spare on board in case the OEM pump fails. And if the intank pump failed on the road could I use the original style to "limp" in on?
Thank you for your inmput. Larry
Questions:
