Details here: TDR Privileges
If this issue started with the installation of the FASS, I'll bet something did not get correctly hooked-up. I'll bet it has something to do with the relay. Does removing the relay stop the pump? Have you tried swapping out the relay (there should be a relay in the under-hood fuse box that will work).
