fuel pump test
TC Question
Valve cover gaskets
I have a used fuel pump and was wondering if they can be tested off the engine. If so how do you do it?
Dewdo in the other Washington
test of pump off eng?
To some extent yes put hose on intake to a fuel container supply 12v to pump with long hose on out port use long hose up hill to at least eight feet with a psi gauge in line restrict line with a small orfice about 2/32 about a foot from pump out put side will not be accurate but will show if pump is putting out any psi and flow . Rember restriction makes Psi Pumps make flow and our system has a pop off return valve in line . do this test if you will but it could be a mess , do it out side easy clean up area , clear plastic hose and you can see the flow . Ron in LOUISVILLE KY :confused: :confused: :confused: Oo. :D
Thanks for the info Ron. It does sound like a messy job. Probably be easier to put it on and read the pressure off my gauge.
