Engine/Transmission (1998.5 - 2002) fuel pump
Engine/Transmission (1994 - 1998) Life expectancy
have 1998.5 ram 2500 with air dog raptor block mounted pump. pump went bad will be replacing pump. my question is I here the problem with this pump they don't like to pull fuel that far from the tank. will it help to install a supplemental pump by fuel tank to push fuel to the raptor?
Get the Frame mount bracket from Geno's and the Carter/NAPA and relay and all is well. I am running my own frame bracket/filter arrangement with Holley Blue and it is OK for an $80 pump , makes 14 psi and 10 psi WOT and has for over 6 years. Had it to do over I would probably choose a different pump and if I have a failure , I will, but I have the replacement rotor kit from Holley ( $7.95) in the booney kit and that is hard to beat!
gtwitch in wyoming
