Fuel quantity
10K Blues (low power problem)
EZ,B-D,VA? What one is better???
I just had my pump gone through, needed the barrels balanced and an oil leak fixed. Any way I now have 350 cc's of fuel being delivered at 1250 rpm. Last time my pump was checked I only had 252 cc's .
Does anybody know what kind of horsepower that's giving me ?
By the way if anybody has added some custom cut delivery valves and you have a off balance idle, having the barrels balanced on the injection pump may solve your problems. It did for me.
Brian Cobb
97 2500 CC 4x4 5 speed,egt & boost gauges, #5 tst,370hp injectors,4" exhaust,16cm turbo,Governor spring kit
afc kit,Pro Shot 2000,Psychotty Air, ceramic brass clutch,prozap, High flow delivery valves
illflem, Oregon fuel injection did the injection pump work. A local dealer did the R&R under warrenty. The oil leak was covered under warrenty, but the the balanacing I had to pay for. It cost me 250 bucks.
The truck runs MUCH better now, it's alot smoother. Well worth the money spent.
Brian Cobb
