I relaced mine years ago when I went to the dealerr for the fuel sender they sold me the whole unit for around $250. I have since learned the sender is sperate for around $30. 00. The last time I replaced the sender I noticed the lines were rusty and decided to just "fix it" I don't remember what i did but I was able to take a regular copper pipe fitting think it was about 1" or 1 1/2" copper cap that fit perfect in the the part i had to remove from the top of the pick up unit. I drilled 2 holes in it and soldered barb fittings onto it installed rubber fuel line coiled in the unit so it would work with the float for the pick up and cut off the factory quick connect and plastic hose and repaced with rubber hose and clamps. I would have just bought the p/u assembly but I had not realized it was rusting out until I had dropped the tank. The dealer did not have the pick up in stoch so I would have had to put the truck back together and taken it apart agin when the pick up came in. took me bout an hour or so to modify it. I planned on replacing it but its held for 2 or 4 years now so I pretty much forgot about it until I read this thread
