Trying to get that darm fuel selenoid off in the driveway and I find that the selenoid shaft is rusted to the fuel pump level.
(That little shim in the rubber gromet at the end of the rod is rusted to the lever shaft)
I see 2 bolts that hold that fuel pump lever to what seems to be a small fuel pump shaft (that shaft must be connected to the pump stem).
the top bolt has a nut at the end but I can't tell what the bottom bolt's got.
If I take those 2 bolts out, am I asking for trouble?
thanks.
thanks.
