Originally posted by GFreshour
I got this info from this board previously, I have not tried it yet:
Your fuel gauge problem is due to the sending unit in the tank going bad. Don't
spend the money to buy a new one though. The fix is so easy and cheap (cost49 cents).
This is the most common problem but NOT ALWAYS the problem.
My '96 stopped working after 2 years (but outside of the 36K warranty) due to the white metal slider piece hanging up. When this happens, it changes the pivot elevation of the fuel float causing an inaccurate and non-repeatable readings as it would catch high, then low, etc.
I have run almost 4 years (90K) without a functional guage. Repaired the slots once but it is now too worn to work at all. Will have to replace the entire unit unless someone has the white metal top piece of the intank module as a spare... ...
Running empty is no problem because I have a good idea of the fuel mileag. Running various loads makes it interesting to keep track of the amount of fuel remaining.
