Fuel Sending Unit Location
dimensions of cubby under heat controls?
transmission
brickerd
I just got my 03 a couple weeks ago and I need some help already. I'm working on remounting my gauge cluster out of my 99 and DC moved the fuel pump on me or at least it looks different now. My question is where/how do I or should I mount or tap into a line for mount my fuel pressure sending unit? Previously I had mounted it in one of the "testing" ports in the filter. I tried both the pre and post filter, don't remember exactly where it ended up (pre-filter I think), but now everything looks different. I want to assume that the best course of action is for me to get a banjo bolt that's tapped for an 1/8" fitting, but I'm not 100% sure if there are any other options. If that's the best route, then where is it best to mount it (in which line)? I'm sure that I'll get the answer I need soon, so thanks in advance, Don
