2nd Gen Non-Engine/Transmission fuel sending unit wire
Engine/Transmission (1998.5 - 2002) software for laptop for codes etc
Engine/Transmission (1998.5 - 2002) 300HP 24V Injectors
I put a transfer tank in the bed on my dads 97 12 valve & im trying to find the correct wire for the fuel sending unit. I will tap into the harness in front of the stock tank but i cant find what color the wire is. The tank has a electric sender in it that allows the stock gauge in the dash to work on both the stock tank & the transfer tank. There is also a switching valve that i have wired to a toggle switch in the cab to switch from one tank to the other. Thanks for all replys.
Kurt
