Went to make some adjustments on the AFC because I wanted less smoke (I Know) anyway as I was getting ready to remove the AFC cover, the Fuel shut down solenoid fell off. Long story short, I have a new boot on, replaced the third mounting bolt that also was missing, and now I'm trying to determine what I should use as a retainer clip for the plunger. By that I mean, the plunger attaches to a stud on the linkage and the stud has a small hole thru it for some kind of keeper. The factory manual doesn't show what is used, so hoping someone here can get me looking in the right direction. I have a very small cotter pin there right now, but I doubt it would last long. I'm thinking some stainless wire thru the hole and twisted would work. Similar to how wire is used in the tamper proof spots on the pump. Also need to know the size and pitch of the metric bolts that hold the AFC cover on. I have one that is stripped and want to go one size larger and tap out a new hole for it. Thanks
