Engine/Transmission (1994 - 1998) fuel shut off solenoid trouble please help
trouble is at the coupling for the wiring at solenoid. When the key is on the constant power is good and the ground is good, but the power that opens it does not work. When everything is plugged in, but it will power if I take the constant power and disconnect it. What may be the problem. Truck will start once an a while when all three are plugged in. Any suggestions please help, tired of opening it manually.
Darin
Do a search on fuel solenoid to get the complete information about it and what can go wrong. The relay is most often the cause of what you are seeing. It may also be the blue fuseable link on the positive post of the driver's side battery.
