Ok, I have just replaced the Batts, starter contacts, shutdown solenoid, and shutdown relay. The same intermittant problem still exist. The truck may or may not start when the key is activated. Sometimes it will start but not stay running. After trying multiple times it will start and continue to run with no side affects. Has proper voltage at the wiring to the solenoid. What is the dimention for proper adjustment of the solenoid rod. The rod is supposed to be pre-adjusted, but it makes me wonder. Any ideas would be helpful!!
I love electrical problems!!
