A few years ago my fuel shutoff solenoid (1998 12v, manual) went out, and I just replaced it with a PTO cable as many on here have. I put in a FASS pump this weekend, and found all my old solenoid parts and a LarryB relay I had bought some time ago. I figured since I was already working on the fuel system, I might as well try repairing the solenoid. I swapped in the new relay, and then checked the voltage at the connection. I have 12 volts between the GROUND and HOLD wire, and sure enough when I push the piston into place (with the truck in RUN), the solenoid holds it up. However, when the truck is in RUN, I have 1.5 volts between GROUND and PULL. When I switch to START, the voltage (slowly) increases to 5 volts. I assume I should have 12 volts.
I looked in the factory service manual, and followed the circuit to the solenoid. Power should be flowing from fuse 9 in the PDC (checked out good), through the closed relay (just replaced), to the PULL wire of the solenoid. And if I get 12v between HOLD and GROUND, I know the ground is good.
What do I check next? Thanks.
