Or get used to using the manual shut off. There has been a ton of discussion about this. I think it has been decided that if you want the high performance, that you either have to be willing to buy a shut off solenoid every couple weeks (you can't get just the tip), or run a cable to the manual shut off. I think that I saw someone post about trimming the rubber tip somehow so it doesn't stick out so far and get torn up, not sure how that worked out. FWIW, I've been using the manual shutdown for about 3-4 months now, you get used to it. The other alternative is turning down the pump, like you said. If you do a search on this, you'll find a ton of info.
AJ
