Fuel Solenoid Cutoff Switch
205 shift knob
Good Price on Cross Flow Radiator 92-93
I am wanting to install a toggle switch under the dash to break the circuit to the fuel solenoid, as a poor-man's anti-theft device. Has anyone done this? It would sure help to know which wire to interrupt. This is on a '93.
Thanks,
dbrimhall, I did this on my 92. There are two wires going to the fuel solenoid (one is black & other is blue). The blue wire worked for me. Just to make sure, unplug the blue wire and see if it is the correct wire.
Al
Al,
Thanks for the reply. I was pretty sure I rembered it was the blue wire. What I was looking for was how to identify that wire out of the bundle under the steering column so I could tap into it there for the switch. Any ideas?
Thanks,
There was a great tech article on this 'Cut Off' switch modification in a past TDR Magazine. I've search all of my past issues for the article & can't find it... It's probably in the one issue that I loaned out to a buddy and never had returned.
Have you checked Dave Fritz's webpage for info on this mod?
KEENO:D
dbrimhall, I didn't want to mess with the ignition wiring so I ran a couple of wires to a toggle switch under the dash. At times it is rather embarrassing when I forget to activate the switch and the mighty cummins turns over without immediately starting.
Keeno, Issue 26 of the TDR magazine on pages 16-17 dealt with this topic.
Al:
HEY! I still have that Issue... . My buddy must of made off w/ a different issue!
Thanks for the reminder and Info!
KEENO:D
