cut off solenoid
I hope you checked your wiring connection first. I thought my solenoid was bad, but posted a question. Someone was good enough to tell me to check the wiring connection. That was my problem on a 93 with 210. 000. I just pulled wire connectoers off, cleaned them with brake cleaner, then crimped down a tiny bit on the female end to make a good tight connection. Fixed the problem. If you haven't tried, do this. you might also run a jumper directly to the solenoid to see if you can hear a click in it. Just a thought. Good Luck.
