Fuel supply line from filter to front of inj. pump
Left side cab corner
First Gen Body Lift
Cummins lists the fuel pump supply line as 3918641 (probably superceded so dont be suprised if they give you a different number). However, this should get you started.
Using the numbers assigned to each part, refer back to this so you can see what part number corresponds to each part.
1. 3908988 Tube Fuel Supply
2. 3905351 Seal, Grommet
3. 3918641 Tube Fuel Supply
4. 3905351 Seal, Grommet
5. 3908985 Union, Male 9/16-24 x 9/16-24
This info courtesy of Mony Dyer.
pb... .
