Engine/Transmission (1998.5 - 2002) Fuel system help
hello everyone,
I have been following the forum for some time now and am undecided on what to do about my fuel problems. The dealer installed a new vp44 at 35k and new lift pump. At 75k the lift pump went out again and they installed the in tank setup. I am getting crappy fuel pressure (0 at wot with comp cranked up) and would like to bring it up. Should i do away with the in tank pump completley and if so is there a draw straw kit available that will replace the in tank setup (vulcans kit wont and they say to check out the draw straw II but i cant find it)? Can i get away with adding a secondary pump on the frame rail? I want to try to fix this fuel pressure problem without draining my wallet.
thanks for your help
joe
2002 qc 2500 4x4 5 speed,short bed,isspro exhaust fuel and boost,bhaf,drag comp,no muffler,pump cover.
You will save a lot of time and cash by going with a good system. Either go with a FASS (HPFP or the Full sytem) or a Walbro kit. Definatly go with the Draw Straw II. Here is a link to the picture of the Draw straw II. www.wideopendiesel.com/page8.html It is down at the bottom of the page and also has the install instructions there also.
