Engine/Transmission (1998.5 - 2002) Fuel System Upgrade
Engine/Transmission (1998.5 - 2002) no power after 2000 rpm
Engine/Transmission (1994 - 1998) Jasper Transmissions
I am going to drop my fuel tank soon. SInce I will have it out I think it makes sense to get it ready for some new bombs that will be coming soon. I have read a lot on here about fuel line and banjo upgrades. I want to make 450 HP when done. What fuel system upgrades will I need to make? Larger lines? Where would be a place online I could order from?
Thanks
Phil
Do I need to install larger fuel lines and replace the Banjo fittings with the FASS? Does it come with those parts? If not, what would you recommend?
Thanks
The system will come with larger fuel lines and all the fittings you need to install it. I think about the only other thing needed is a good supply of zip ties. The fittings are called push lok fittings and sometimes are a little tricky to get slid all the way on so one of mine has a small clamp on it just in case.
