Hi - i'm going through my fuel system to ensure no air leak integrity and have some questions I could use help with. Following Joe G write up.
Truck is 95' 101K miles, last fuel filter change 7 yrs and 17K miles ago. Driven sporadically as it is really a tow/vacation vehicle (Unfortunately).
What I've done so far:
1. Eliminated fuel preheater - it was clean and no apparent leaks.
2. Replaced pre-filter - it was clean - clean fuel, and very little sediment - looked like a few sand particles.
3. Replaced pre-filter to lift pump hose - it had internal hose spilt - visible if you squeezed it.
4. Pulled primer plunger from lift pump. mostly dry in the boot cover, but when plunging 1st time a teaspoon of fuel came out, perhaps it leaks past the plunger plastic ring seal).
5. Removed main fuel filter, 1st half cup of fuel came out separator tube clean. After moving the filter sideways etc to get it out of the truck the next half of fuel drained from sepator tube came out black - that was a surprise. Perhaps the movement of the filter dislodged black particles.
Key questions:
1. The lift pump primer plunger oring - is it meant to seal on the bore (when plunging) or only seal when it is static - in which the oring is compressed by the spring force holding the plunger outward?
2. Anyone know the original size of the oring (I've scoured the web to no avail). Mine is currently 14x1.6mm (it may have shrunk in cross section thickness though?).
3. Black fuel out of filter - normal considering 17k miles and/or 7yrs and obviously long durations between fuel fillups. I always start the truck every week or 2 at minimum, but not a lot of fuel going through the tank.
Thx,
Paul
Key questions:
Thx,
Paul
