Hopefully I've resized the files correctly and you can view them.....
This is the 80 gal tank we found in the junk yard... . they first wanted $225. 00 and lost it... . we later found it in their scrap pile and purchased it for $35. 00.
It came with brackets and cage as it was off a diesel school bus that was scrapped... .
We ran a line from the bottom of the tank to the side of the stock tank and will later connect the vents..... We expect to fill at truck stop with two nozzles and expect like our larger trucks for it to gravity flow to the main tank... the top of the new tank and filler is the same height as the stock tank..... and the bottom of the add on tank is about 3" higher than the stock tank... .
