Hi to all.
I recently, few feeks ago, had to replace my fuel float, because the dashboard gauge would be showing empty all the time and "low fuel" light would be on ALL the time.
The fuel tank was really clean, but the fine screens on the bottom of the pick up assembly were totally cloged. From white color those had become dark gray.
The fuel float was deterioreted. It was 1/4 from its original size. The replacement I installed was exactly the same thing and I know it will not last long either. It looked as the deteriorating float had clogged up the screens not allowing sufficient amount of fuel to through.
I changed 2 OEM Carter lift pumps in less than 15000 miles, because of really erratic psi readings, and I was still getting the same results!! another Carter was replaced earlier, so those are 4 pumps including the original it came with. My pressure would drop to 0 psi at idle occasionally. My fuel filter was new, and my lift pumps were brand new from Cummins. I even thought my gauge was bad.
How many of you has replaced the float to find out your old one was deteriorated?
Why is the float for our trucks the same part # as for the gas trucks? Yes it was the same part number. I would have to dig it up and will post it.
Is the float deteriorating faster with the ULSD?
I oderered it form a Dodge dealer with the VIN number of my thruck just to make sure.
So, please chime in, let's find out if that deterioration is widespread, and how long do those float last. I changed mine at 76000 mi on the odometer.
Ilian
Ilian
