I installed a 25 gallon auxiallary fuel tank in the bed of my truck with a RDS overflow preventer valve. The valve goes inline of the 1 1/2" fill hose and has a check valve so that the fuel cannot fill past that valve. The problem is the fill hose connects to the tank at the highest point of the tank. The tank fills and leaks out of the top of the tank, the lower part, before it can reach the check valve. Should the tank be leaking from the top? It appears to be leaking from the fuel lift pump assembly.
