Well, my roll-over valve/valves are leaking. I accidentally left the transfer pump on this past trip to TX... must have "popped" one or both of the roll-over vents as I pushed fuel out the vent hose (I have the vents tee'd into a single hose). I find this weird as I have a return line between the two tanks that should have allowed the fuel to simply return to the aux tank...
Now, when I leave my aux tank siphon into the main tank, it drips fuel out of the vent hose if I stop for any length of time.
I have thought about blowing some compressed air through the lines (with the filler cap off) to see if I can re-seat the roll-over valves?? I think those valves can be replaced can't they??
Any ideas what I should do?? As it stands right now, I have to keep the aux tank line valve closed to prevent dripping fuel... my only alternative is to replace the 1/4-turn valve with a low-cracking pressure check valve to prevent the siphoning (forcing me to pump fuel across instead of siphoning)...
steved
steved
