My '98 12valve fuel supply and return fittings at the tank are rotted out and leaking. the dodge dealer says i should just buy the sending unit with the in tank fuel pump. Any positive or negative feedback? I also busted the bolts off that hold the cross member up at the front off the fuel tank, gotta love salt in Michigan, is there any way to get the nuts out? They look like they are welded inside the boxed in part of the frame.
