fuel tank sending unit
Fan Shroud for 91.5
HELP! Need Turbo Elbow for intercooler pipe!
My 90 fuel tank band broke and dropped one end of the fuel tank braking the fuel line off the tank. Dealer said they dont make this any more. I tried napa store and they said it was a captive (dealer) part. HELP thie is my feed truck and my cows are hungry!!!! It is -22 bellow this morning, might have somthing to do with plastic braking.
'92 Fuel tank mounting bands.
Eric,
If you still have the NIB fuel tank mounting bands, I would like to get those from you. I have a '92 in need of new ones to replace the corroded ones before they break. Please contact me asap if I can buy them from you. Thanks.
Sean
Backyard fix
I had roughly the same problem. Broke the plastic piece while trying to replace a fuel line that had rusted thru. Cost of the new tank unit was going to be $300. 00 +. I took a piece of 1/4" aluminum plate, cut it to fit inside the screw on top of the old unit, installed 2 bulkhead fittings (3/8") in the plate. Then I measured to the bottom of the tank, cut a piece of 3/8 copper tube, put a brass tee on the bottom and connected the top to the bulkhead fitting. Then I put a short piece of 3/8 tube on the other bulkhead fitting (return line) and put the little rubber valve from the original unit's return line on it. I then bent 2 short pieces of tubing so they would connect to the feed and return lines on the truck and put them in the top of the bulkhead fittings. Re-assembled an I was "On the road again" I was without a fuel gauge but it never worked right anyway so i didn't really lose anything, and this setup WON'T BREAK!! Hope this helps someone, Max
