Kent Kuykendall
Do 98 fuel caps vent the tank to allow fuel to be pulled out or is there a vent on top of the tank to allow this?
thanks
Kent
thanks
Kent
On my 99, which I imagine should be about the same as your 98. 5, there is a rollover valve on top of the tank. I figured this out a couple years ago when I kept hearing a hissing sound coming from my tank when I had the cap tight, then it would quit when I unscrewed it. The rollover valve was clogged up, someone on here posted a nice little diagram of what it looks like and how to get to it. Popped it off and cleaned it out, it vents properly now.
ISB Low Power Fix
There is a picture of what you will see on top of the tank. I remember it being kind of frustrating popping it out. I guess since it's exposed to the atmosphere it can get debris and such in it, which is what happened to mine. Hope this helps
Don't quote me but I wanna say its a 1/4 turn installation(think marker light socket) I've had this problem twice in one year, I added a small rubber hose pointed down on the side of the tank and haven't had the problem in a few years.
