After the truck has been running warm, then shut down for 10 minutes to approximately 1 hour and started up again, it will surge; there is lack of power. You have to get it rolling best you can, seems if you can get air around the motor, eventually it will pick up power. This happens only when the outside temperatures are 65 degrees and over. The hotter the temperatures, the problem is more severe. I have checked for codes and surprisingly, I don't have any.
Anyone else have this problem? Any idea on what this problem might be.
2000 ETC 3500 4x4 6 speed EZ - X Monitor, Jacobes E Brake
