fuel
edge jammers
94 to 97 Clutch Slave
I Have A Very Strong Fuel Smell Outside The Truck. . It Is Not Very Strong Inside The Cab. The Longer I Drive And Stop The Stronger It Is. . If I Start It Up In The Morning And Drive A Few Miles It Hard To Smell. . Drive 50 Miles And Very Strong. . I Looked At The Lines And Inj. And Do Not See Any Fuel Leaks. . Any Ideas ???????
John Colburn
2005 Silver Qc 2wd 8000 Miles On It
Might be a tiny pinhole leak somewhere in the fuel rail fuel lines or fittings. You probably wouldn't see the leak because under that high a pressure, the fuel would vaporize once it got out of the system. That'd be my guess.
No a dirty filter is still contained in the housing. But, check around the filter housing for an area that looks 'wet'. Also follow the fuel lines and look for 'wet' areas. If you drive on dirt roads alot the wet areas will be covered in dust moreso than the remainder of the truck.
Does the 2005 have the same type of filter as the 2002? If it does than check to make sure the valve on the filter housing is closed all the way. Just some random thoughts.
thanks for all the info..... i will take the truck to the big d in the morning... . we will see what they say...
i will let yall know what they say.....
i did forget to say but i do run a dr. performance mod on my truck... i hope that is not my problem... I will take it of before i go to the big d... ...
I Found Out At The Big D That #6 Inj Tub Was Leaking. . They Say They Fixed It... . We Will See...
Thanks Again For Yall Info
