Fueling options
Bosch 275 injectors
New EDM's
I plan on running a comp box and want to know if the factory lift pump will supply enough fuel and last if I keep check with a gauge?
If not, what other options are there other than the FASS system, and what will it cost me?
PM member Wade Patton and talk to him about the Hi-Flow kit from Wildcat Diesel. He has it on his 99 and he runs a DD UFM (reprogrammed Edge Comp from my understanding:confused: ) and DD3's on his factory turbo :eek: but he said since the addition of the Hi-Flow kit from Wildcat that he can't get the fuel pressure below like 7 or 8psi
I've run the Comp and a set of 275's for over 70,000 turns with the factory lift pump and never had a problem. Course I'm an exception to the rule as I do run a 32 oz's bottle of PowerService about every other tank of fuel. I think this is why my lift pump never failed me.
I have 106,000 turns now and just installed the FASS system at 103,000. Wanted to get it on before the lift pump had a chance to do it's thing to the VP without my express permission;)
I would think you would be ok, but then again the mileage on the Lift Pump would be where you would have to decide on your comfort zone.
Originally posted by TN farmer
. . . what other options are there other than the FASS system, and what will it cost me?
I had to have a new lift pump installed and so I decided to put in for some insurance . . . I had the Wildcat HiFlow system installed. I'm running a TST box and I never fall below 12 lbs. of FP. The parts are very high quality and the cost from Wildcat Diesel is about a buck fifty ($150).
