I had a chance to swap out my AFC pin to try out the 13H Out of my spare pump (see dzlpwr s post AFC pins). I installed and my truck would not start just kick occasionally. I reinstalled the Stock pin and the problem still was there. I have been having some lift pump problems since my Driveway is at a angle when I park i have had some starting problem but everything is cool when I roll it down the hill she started fine. I went out and bought a lift pump several days ago to fix the problem but have been lacking ambition. I swapped out the lift pump and bled it still no start. So I pulled the fuel filter and YUK it was full of dirt has been a while since it was changed. Put in a Spare I had and bled it still no start. I noticed the WIF sensor leaking so I went and cleaned it out reinstalled still leaked removed and pulled it apart (I know it was stupid to pull apart but it is 2 AM) found the Orings bad so I tried to seal by bolting with a thru bolt and a couple of washers and a gasket. Still leaked called it quits and picked up a sensor yesterday. Installed it last night bled no start just kicked. cracked the line at the injector pump and bled got good flow there. No start. bled the injectors ,no start, bled again, still no start, Called it quits. I cut the old filter apart and found there is a bypass and the filter full of dirt and crud. Is my injection pump screwed?? Are my injectors clogged?? Hope not they are a set of PODs with only 350 miles on them. Any suggestions?? Sorry about this being so long.
