Details here: TDR Privileges
Can the full fuel screw on pump be turned up far enough to strain the pump if the stop collar is still on. I turned it right up against the collar and can get 27 # boost.
I don't think the pump will hurt itself with that collar still on. On my 93, I took the collar off, then turned it til it stopped 37psi:--) I then put a good many miles on it with no trouble, so you should definitely be fine.
