I pulled the little tamper-evident cap off of my fuel screw today to do a little adjustin'. After I popped it off, the collar is damn near touching the jamb nut! I loosened the nut and could only turn it a half turn before it bottomed against the jamb nut. Does this sound normal to any of you guys? A little back ground, the pump was changed sometime before 35K when the original owner had the truck (I assume recall). The second owner never messed with anything and all of the tamper caps are/were still on it. I assume this thing was set to the stock spec as my truck was/is no ball of fire, but I figured I'd have more room to screw, if you will. Whatchoo guys think?
Travis. .
Travis. .
