Full Length Nerf Bars
Bully Dog Step V Injectors
Lucerix Mirrors
Somewhere on the internet I have seen nerf bars advertised for the 3500's that go all the way from rear of front wheels to the fromt of the rear fender. At the rear fender they flare out.
Can anyone help me find this add again?
I am at a loss :{ :confused: :{
Thanks!
Yaaaaawn ... ... . Someone Rang ? ;) #ad
<BR><hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Somewhat Powerpacked By Bank's (4 inch exhaust,High ram intake,~Minus~wastgate mod to 38 psi,~Minus~ottomind TLC +guages,K&N) ,Blue Chip Premium FMC DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec's Double Deep Trans pan,DD injectors+Van Aken+Autometer Guages. ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DynaMat Sound deadening applied to entire cab and doors, Check out Tool's Stuff#ad
N. E. T. D. P
Three worded story ... ..... "over 1350 posts - a new record!"
All the way!!
See further details in the sigfile below; picture was taken before I had the Rixon 19. 5 inch tires/rims. Only one word of warning... . if you plan to haul a slide-in truck camper, research the camper tie-downs beforehand - not all are fully compatible with this nerfbars set-up and you may not be a happy camper!!
